Bottlehead Kits
Crack
Choke upgrade question (resolved)
Jimb0
1792
Jimb0
Sr. Member
January 11, 2021, 03:04:34 PM
Quick question, the CX-7 Triad replaces the white 270ohm wirewound resistor on terminal 13L and 15L correct?
Last Edit: January 12, 2021, 04:32:20 AM by Jimb0
Colonl_Charisma
Full Member
Re: Choke upgrade question
Reply #1 on:
January 11, 2021, 03:26:17 PM
Yes, you are correct. It can replace either of the resistors on the power supply unit. Most people replace the resistor between the 2nd and 3rd capacitors with the choke which is the one you are referring to.
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Jimb0
Sr. Member
Reply #2 on:
January 11, 2021, 03:39:35 PM
Much appreciated!
Colonl_Charisma
Full Member
Reply #3 on:
January 11, 2021, 06:59:02 PM
You’re welcome!
Ross
Bottlehead Kits
Crack
