Failed voltage check. [tentatively resolved]
andyh · 3734
Offline andyh
on: January 13, 2021, 12:20:52 AM
I think I must have missed something but can't see it. Voltage check
1 -0.7
2 -0.7
3 0
4 -0.7
5 -0.7
6 0
7 0
8 0
9 0
10 0
I,ve gone all the way through the manual following the wiring instructions and can see nothing wrong/incorrect. :'(
« Last Edit: January 14, 2021, 11:32:33 AM by Paul Birkeland »
Offline Deluk
Reply #1 on: January 13, 2021, 02:47:36 AM
First thing I'd do is check the fuse......................
Offline andyh
Reply #2 on: January 13, 2021, 02:49:13 AM
Tubes are glowing so assuming it's ok. (Checked, fuse is ok)
« Last Edit: January 13, 2021, 02:52:21 AM by andyh »
Reply #3 on: January 13, 2021, 03:27:03 AM
Make sure that (1) you've got the test leads plugged into the correct jacks on the meter; and (2) you've got the meter set to measure DC volts not AC volts.
cheers, Derek
Offline andyh
Reply #4 on: January 13, 2021, 03:40:07 AM
Yes checked, also checked with a second meter just in case.
« Last Edit: January 13, 2021, 03:47:32 AM by andyh »
Online Paul Birkeland
Reply #5 on: January 13, 2021, 04:01:06 AM
I see a diode lead at 19L that's poking out and maybe touching another lead, which will short out your HV supply (and should blow the fuse).
Can you perform the power transformer voltage test that's in the manual and let us know what you get on the high voltage winding? (The one that should be about 160V)
Offline andyh
Reply #6 on: January 13, 2021, 04:15:06 AM
Hi Paul,
Black lead to term' 11 red to 12 on transformer, it's reading 175v.
Reply #7 on: January 13, 2021, 04:23:41 AM
How about the DC voltage between terminal 20 and 21?
Offline andyh
Reply #8 on: January 13, 2021, 04:26:16 AM
235v
Offline andyh
Reply #9 on: January 14, 2021, 08:12:07 AM
Any ideas anyone??
Reply #10 on: January 14, 2021, 08:16:57 AM
How about the DC voltage between terminal 3 and terminal 20?
Offline andyh
Reply #11 on: January 14, 2021, 09:20:48 AM
3-20 = 0v
out of curiosity I measured 3-19 =90.7v
Reply #12 on: January 14, 2021, 10:24:04 AM
How about the DC voltage between terminal 3 and terminal 15?
and the DC voltage between terminal 3 and terminal 13?
Offline andyh
Reply #13 on: January 14, 2021, 10:33:03 AM
3-15 = 196v
3-13 = 172v
Reply #14 on: January 14, 2021, 10:35:37 AM
Voltages between 3 and B2?
3 and B5?
