Issues [resolved]
Markkr · 27342
Offline kgoss
Reply #15 on: February 04, 2021, 04:07:52 AM
In the picture you labeled "B" the black wire in the bottom right going to a terminal strip does not look soldered.  It has not been crimped to make the mechanical connection.  Also it looks like the wire has been pushed so far the insulation is in the terminal rather than the wire.  If that is true there is a very poor or no electrical connection.
Ken Goss
Offline Markkr
Reply #16 on: February 04, 2021, 08:01:47 AM
"nearly impossible" is my middle. name  ;)
I disconnected 19 and 20... voltage on 3 & 4 on both sides is 6.5v AC
FWIW, the 6AQ5's glow now that 19 and 20 are removed
« Last Edit: February 04, 2021, 08:08:51 AM by Markkr »
Offline Markkr
Reply #17 on: February 04, 2021, 08:04:52 AM
I re-heated and secured that black wire just in case. Thanks for the feedback
Reply #18 on: February 04, 2021, 08:14:19 AM
Disconnecting 19 and 20 does not make the 6AQ5s glow.  If you had 6+V AC on the transformer where the STP connects (I had you measure this), your 6AQ5s will glow.
There's a loose connection in the STP wiring from the transformers to pins 3/4 on the 7 pin sockets.  You'll need to find that before proceeding.
Offline Markkr
Reply #19 on: February 04, 2021, 08:22:29 AM
Will do, just so happens that I ordered a spare wiring kit for this amp, so I will just replace that STP with new pieces.
Offline Markkr
Reply #20 on: February 04, 2021, 09:32:10 AM
okie dokie!! That fixed that problem! The voltage tests all pass WHOO HOO
haha, my hopes were quickly dashed when I tried headphones and only sound coming from the left channel. (man I suck at this)
I found errors in my wiring of the potentiometers... corrected them... still no sound in the right channel.
ALL RESOLVED
@Paul, THANK YOU again. Your help was very much appreciated
« Last Edit: February 04, 2021, 10:44:58 AM by Markkr »
Reply #21 on: February 04, 2021, 11:24:31 AM
What exactly ended up being the issue?
Offline Markkr
Reply #22 on: February 04, 2021, 02:15:15 PM
I had miswired the pots, confusing the “front” and “rear” in the directions. I pulled it all apart and rewired correctly.
Reply #23 on: February 04, 2021, 02:28:25 PM
That made the 6AQ5s not glow?
Offline Markkr
Reply #24 on: February 04, 2021, 03:03:36 PM
The 6aq5’s started behaving after replacing the STP cables with new ones.
The channels began behaving once I corrected the pot miswire.
Reply #25 on: February 04, 2021, 03:06:49 PM
Ah, excellent, I'm glad you got it all sorted out.
Offline Markkr
Reply #26 on: February 05, 2021, 02:17:51 AM
Thank you again!
Reply #27 on: February 05, 2021, 05:55:40 AM
My hunch is that the root problem in this one was nicking the wires when they were stripped, which lead to some wire breaks just inside the insulator where they were not easy to spot. Generally this is caused by using something other than a wire stripper that is sized exactly for the wire gauge being stripped.
Offline Markkr
Reply #28 on: February 05, 2021, 12:52:47 PM
Can you confirm the gauge of the wire included in the kit? I was using Hakko strippers in the 24ga spot.
Offline Markkr
Reply #29 on: February 05, 2021, 01:10:23 PM
Also, new question.
The 7 pin sockets are VERY loose when tubes are inserted, the pins grab the tube just fine but the pins are "floppy" in the ceramic base. I contacted Eileen and she sent me 2 new sockets but they are exactly the same way. Is this expected?
The socket is 2 ceramic pieces, and that's where the "play" is coming from. Should I simply epoxy them together?
