Eros2 with 6BR7 voltage checks and a question
johnsonad · 2518
Offline johnsonad
on: February 07, 2021, 05:41:25 AM
I finished the Eros2 build this morning.  I subbed in the 6BR7 for the EF86.  No other mods were made other than a different pair of OPT capacitors.  Voltage checks are listed below.  All are within specs minus OKC/OKD. Wall voltage was between 119v/120v (with a variac maxed out).  My wall voltage sucks..... It sounds great :)
IA: 214.7
IB: 218.6
OA: 163.9
OB: 165
OC: 97
OD: 96
OKA: 98.3
OKB: 97.4
OKC: 2.84
OKD: 2.91
The OKC/OKD voltages drift down slowly as it warms up.
Reply #1 on: February 07, 2021, 06:34:41 AM
Well, the servo is doing what it needs to do.
Offline johnsonad
Reply #2 on: February 07, 2021, 06:43:44 AM
That was my guess.  Seems to be working hard ;)
So if the OKC/OKD voltages were sub 2v, then the circuit is idling and vis versa?
Reply #3 on: February 07, 2021, 06:44:57 AM
A class A circuit is always at full throttle.
Offline johnsonad
Reply #4 on: February 07, 2021, 07:01:43 AM
Is my build then adding a NOS tank to the servo? 😳
Reply #5 on: February 07, 2021, 07:04:02 AM
No, the 6BR7 needs a different bias voltage than the EF86.
Offline johnsonad
Reply #6 on: February 07, 2021, 11:47:39 AM
Thanks for taking the time to bridge my knowledge gap PB!
Offline BNAL
Reply #7 on: February 09, 2021, 09:05:49 AM
Aaron,
Nice, another kit. Sounds like your back in the swing of building.
What caps did you use in this build?
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline johnsonad
Reply #8 on: February 10, 2021, 02:05:43 AM
Hi Brad,
I had some extra 1uF Solen SM polypropylene film and foil caps for the outputs.
