Faulty Left Channel
Mesz77 · 2972
Offline Mesz77
Reply #15 on: February 25, 2021, 02:02:18 PM
It doesn't cut the audio when I wiggle it
Brandon Meszar
PSU
Offline Deluk
Reply #16 on: February 26, 2021, 01:01:20 AM
Off the wall suggestion. Remove some of the solder on the headphone jack link wires as if you were going to remove them. Plug in you phones and reflow the connections. That may allow the sections to "relax" and re align the contacts. You could try this first with the plug in if you wish. Will it help? I don't know.
Offline Mesz77
Reply #17 on: February 26, 2021, 07:56:20 AM
I haven't had any problems with the amp since yesterday, but ive been looking into other headphone jacks. If I were to get the one in the link how would i go about wiring it?
https://www.digikey.com/en/products/detail/153X/153X-ND/1290423
Brandon Meszar
PSU
Reply #18 on: February 26, 2021, 08:16:36 AM
Well, that's a mono jack, so you'd lose output to the right ear cup under all circumstances.  It's also not insulated, so you would put the chassis plate in the signal path which isn't ideal.
