Carbon Comp resistor drift
Neuronal · 1532
Offline Neuronal
    • Datta Lab Website
on: March 01, 2021, 06:14:11 AM
I am doing the soft start upgrade for the Paramounts, and because I have read good things about them I went ahead and bought a bunch of Allen Bradley 220 ohm carbon comp (NOS) resistors from Federal Connectors to use as grid stoppers. I did the thing where you heat them gently for a day in an oven to blow off any water and then seal with shellac, and to my surprise after that all (20 resistors) read 230-240 ohms. So I ordered another 20 and before heating them took resistances - again all are between 230-240 ohms. This isn't just the 5% error because it is systematic - they all are too high by about the same amount. I know carbon comps drift over time - is this basically a sign that these are going to be noisy and I shouldn't use them? I have a bunch of new Arcol carbon comps as well which measure perfect on my ohm meter (a positive control!), so I could just use those instead, but I was wondering whether this is par for the course for the ABs and doesn't predict noise levels in a circuit, or whether I should just use the Arcols and call it a day instead. Thanks for any advice!
Bob D
Rega P2, Cosecant DAC, Reduction, EFP III, Paramount V1.0 + soft start, Omega CAMs + DeepHemp 8s
Reply #1 on: March 01, 2021, 06:39:15 AM
For a grid stopper, you don't really need to do anything like this.  They could drift 100% in either direction and you'll never hear anything, and I wouldn't expect them to ever really get noisy as grid stoppers.
In a position where they experience significant thermal dissipation, things can get a bit different.
Offline galyons
  • Geary Lyons
Reply #2 on: March 01, 2021, 07:28:51 AM
Just curious! Did you measure them before processing?
Cheers,
Geary
Offline Neuronal
    • Datta Lab Website
Reply #3 on: March 01, 2021, 07:48:56 AM
for the first batch I didn't, which was a mistake. After the first set of high readings I thought the heat might have caused some sort of systematic drift upwards (or, since I used pre-dissolved shellac, that maybe some aqueous component of that might have hydrated the resistors), which is why I ordered a second set. But the second set of resistors reads high before I do anything, so this is probably about the resistors themselves. These are all NOS of unknown age - I wonder whether this is just a general feature of old carbon comps that they tend to rise over time.
Bob D
Offline Tim G.
Reply #4 on: March 01, 2021, 08:07:22 AM
They definitely tend to drift, but like Paul mentioned it tends to be driven more by they heat they are exposed to over time.  So NOS ones I would expect if they were stored properly should be ok.  And wouldn't those be 20% tolerance anyway, so anything between 200-250 would be within their standard readings I would think.
Tim
Offline Neuronal
    • Datta Lab Website
Reply #5 on: March 01, 2021, 09:27:22 AM
Bob D
