Constant Crackling noise
Philip_dop · 1165
Offline Philip_dop
on: March 05, 2021, 06:04:31 AM
I built my crack a while back.
Now it seem like a problem has started, it crackles quite a bit now where it's unusable.
I've check the resistance and found some issues but not sure what is the cause.
When testing resistance,
Pin 7 and 9 show OL, sometimes it shuts off my voltmeter.
and then pin 13 is also OL doesn't change
I've checked all the solder joints they are solid from what I can see.
It was working fine for a while then this just started.
Please advise
Thanks so much
Reply #1 on: March 05, 2021, 06:14:59 AM
Does your Crack have a Speedball?  If so then the  resistances at 7 and 9 won't be 3K (since you pulled out the 3K resistor to install the Speedball).
How are the voltages?
Offline Philip_dop
Reply #2 on: March 05, 2021, 06:28:48 AM
the voltages are 5-10 volts over.
And yes I do have a speedball kit on it.
Thanks for the help Paul.
Reply #3 on: March 05, 2021, 06:29:27 AM
Can you post the voltages for terminals 1-10?
Offline Philip_dop
Reply #4 on: March 05, 2021, 06:41:27 AM
1 76.6
2 180
3 0
4 176.8
5 89
6 3.5mv
7 101
8 .7
9 106
10 0
Reply #5 on: March 05, 2021, 06:44:39 AM
If you tap on either tube or the chassis plate, does it change the crackling?
Offline Philip_dop
Reply #6 on: March 05, 2021, 06:48:36 AM
yes it does, if i tap the volume knob side it either stops or crackles a bit more.
if i hold the plate down it stops
« Last Edit: March 05, 2021, 06:50:36 AM by Philip_dop »
Reply #7 on: March 05, 2021, 06:50:21 AM
That would tend to suggest that you have a solder joint in the amp that isn't 100% functional.  Reheating all the joints will very likely make this issue go away.
Offline Philip_dop
Reply #8 on: March 05, 2021, 06:51:08 AM
Thanks So much Paul, I'll try that and let you know.
