Zero Ohm resistor
debk · 7545
Offline debk
on: March 08, 2021, 05:03:39 PM
Why use a zero ohm resistor instead of length of wire?
Just curious
Debra
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Reply #1 on: March 08, 2021, 05:10:29 PM
I asked the same thing, it's easier to use it in that position rather than trying to cut and strip both ends of a tiny piece of wire...John
Offline Tubegopher
  • Don Palmer
Reply #2 on: March 08, 2021, 07:31:46 PM
OK, I can't help but think that you two are pulling my leg! A zero ohm resistor? Who'd a thunk!  ;D
Offline johnsonad
Reply #3 on: March 09, 2021, 01:28:41 AM
The Eros2 build uses a few of them to replace small pieces of wire in the 9 pin sockets.
Reply #4 on: March 09, 2021, 05:50:48 AM
That's the other reason :)
Really though, stripping a short piece of the teflon insulated wire is a frustrating experience.
Reply #5 on: March 09, 2021, 07:47:12 AM
For those of you who don't know PB's sometimes incomprehensible sense of humor, this is a prime example. But as he says, it does have practical value. Other manufacturers would tell you about the virtues of a "true zero ohm resistor" and spout some stuff about happy electrons and pure unadulterated pathways through which they travel or some other babble. We just use 'em because they are easier to install.
Reply #6 on: March 09, 2021, 05:20:23 PM
To get the Virtues of them you have to use -0 values but they're very difficult to source...John
Reply #7 on: March 09, 2021, 05:41:57 PM
And for those extra critical signal applications that normally call for just a regular 1 ohm resistor, I find sqrt(-1) value resistors vastly superior. It puts the signal electrons in that magical sounding quantum state of being neither +ve nor -ve.  Some say it's imaginary, but don't you believe them.  ;D
Offline TheMilford
Reply #8 on: March 10, 2021, 03:46:58 PM
Timely post. I'm right in the middle building my kit and my 0Ω resistor lead just snapped. I was gonna ask if I can just use some wire instead...
Reply #9 on: March 11, 2021, 05:23:05 AM
Oh man, I don't know...
Offline johnsonad
Reply #10 on: March 11, 2021, 02:06:45 PM
Yes you can :)
