Help with stock crack - left channel with no sound
walajeremias · 2682
Offline walajeremias
on: March 23, 2021, 03:26:07 PM
Hello everyone!
I'm havinf some difficulties with my stock crack. Currently I'm listening to put my build under test before install the speedball upgrade.
Since I was having some microphony and suddenly my left channel had no sound (tested the headphones, they were not the problem) I started reflowing everything and ended up breaking (I thing it was almost broken) one of the hlmp leds.
Since I live in Brazil and the shipping cost will be a little high, I would like to share my build in order to find any more faulites, so I can buy more spare/replacement parts within the same shipping.
If there is any more photos or any other things I shoud do, just ask please.
By the way, does the led have any function beside light? Could I use a wire/other led until the new leds get to me?
Thank you in advance.
Reply #1 on: March 23, 2021, 03:43:07 PM
2L and 4L could use a little more solder.
You can remove the broken LED and install a wire from A3 to A8 and your Crack will work normally again.
Reply #2 on: March 24, 2021, 01:37:31 AM
Thank you Paul!
I will work a little more and test it.
Also, is there any other reemplacent that is always handy to keep, besides led?
Reply #3 on: March 24, 2021, 06:05:38 AM
Once the kit is operational you should look at having a new tube set purchased within 10-20 years.
Reply #4 on: March 24, 2021, 02:01:33 PM
hahaha
I really have a hard time to decide which one is better: the bottlehead product or the forum.
Paul once again thank you for your fast response! Stay safe!
Reply #5 on: March 24, 2021, 02:14:52 PM
The broken led war from A3 to center pin (attached photo).
The A8 to center pin led is good.
Should I attach a wire from A3 to center pin or A3 to A8?
Reply #6 on: March 25, 2021, 05:17:07 AM
Yes, you can add the jumper as a stop gap measure to get the amp back up and running.
Reply #7 on: March 25, 2021, 05:41:55 AM
Ok!
However this jumper will be from a3 to center pin or a3 to a8?
Reply #8 on: March 25, 2021, 05:54:24 AM
Ok!
Reply #9 on: March 25, 2021, 06:05:17 AM
Thanks once again Paul!
