Weller wst 82 thermo wire stripper
Applemacman · 7106
Offline Applemacman
on: March 30, 2021, 09:00:57 AM
Hi,
Seeking help regarding the weller wst 82 thermo wire stripper, does anyone know if this will work with the weller WE1010 work station. If not can someone surgest a two input weller station it will work with.  Thanks
Reply #1 on: March 30, 2021, 10:16:10 AM
Looks like the minimum requirement is an 80W station. Weller seems to match it up with the WR2 station in their literature.
Offline Thermioniclife
Reply #2 on: March 30, 2021, 10:28:48 AM
YIKES that power supply is expensive.
Offline Applemacman
Reply #3 on: March 30, 2021, 11:34:55 AM
Yikes it is. That station is 300watts the thermo stripper is 80 watts so my train of thought was as long as the stations is over 80 watts its ok or is that a bad assumption
Reply #4 on: March 30, 2021, 12:06:40 PM
That's what Weller says, 80W is enough. Suggest you look at their catalog if you haven't.
Offline Applemacman
Reply #5 on: March 31, 2021, 10:40:53 AM
Thanks for the help. I think I found one which is 80 watts cheaper than the wr2
