Bottlehead Kits
Crack
Need to identify version and get manual for used Crack + Speedball
manicmidget
7772
3
manicmidget
Jr. Member
Re: Need to identify version and get manual for used Crack + Speedball
Reply #30 on:
November 29, 2022, 03:04:59 PM
Yep, I am absolutely sure it's not. Might not be visible in the photos but I've checked from every angle.
Just in case the tube was damaged somehow by bad assembly, could you please let me know what each pin on the octal socket should be connected to?
Thanks so much for all your help!
Last Edit: November 29, 2022, 03:07:27 PM by manicmidget
Paul Birkeland
Global Moderator
Hero Member
Reply #31 on:
November 30, 2022, 04:12:10 AM
I would just replace that 6080 and see where that lands you.
That issue can't be caused by build issues, as the glowing heaters in both sides of the tube connect to the same pins, and it looks like one of those heaters has become disconnected.
manicmidget
Jr. Member
Reply #32 on:
November 30, 2022, 04:38:06 AM
Gotcha, I'll report back once I get a new tube. Thanks again!
3
Bottlehead Kits
Crack
