Question on replacing the 3 220uf Cap with Film
wabibito · 2338
Offline wabibito
on: June 12, 2021, 05:46:59 PM
I know this question has been asked a lot but I just want to confirm since this is the first time I build the crack. My understanding from all the reading so far is if I have the choke install, I can use a film cap less than 220uf. My question is can I replace all three cap with 3 Panasonic EZP-E50107MTA CAP FILM 100UF 500VDC?  I have replace the two front with these. I am attaching the picture of the build so far.
Thank you much!
Reply #1 on: June 12, 2021, 06:10:42 PM
Well, if you have already done 2 and have the other in hand, pop it in there and see if the supply is  quiet enough for you ...John
Offline wabibito
Reply #2 on: June 12, 2021, 06:12:27 PM
I will need to buy 3 more. But since they are only 100uf. I just want to confirm it would work hand in hand with the choke.
Reply #3 on: June 12, 2021, 06:50:33 PM
It's not a bad idea to leave the last power supply cap a little bigger.  You could put two of those 100uF caps in the last position and leave the other electrolytics.
Offline wabibito
Reply #4 on: June 12, 2021, 06:57:27 PM
Thanks Paul. How would I go about wiring two of the 100uf cap?  Do I just wire them in parallel?
Reply #5 on: June 12, 2021, 07:03:24 PM
Yes, wire them in parallel.
Offline wabibito
Reply #6 on: June 12, 2021, 07:10:20 PM
Thank you. I also notice some people bypass the film cap also with a 1% uf value film cap. Does it provide similar outcome as bypassing the electrolytic?
Reply #7 on: June 12, 2021, 07:11:48 PM
You'll have to do that experiment and see what you think.
Offline wabibito
Reply #8 on: June 13, 2021, 05:24:57 AM
Thanks Paul. Does this act as a 200uf?  If that is the case the max these Panasonic goes for is 110uf. So I can get 2 110uf.
Reply #9 on: June 13, 2021, 05:39:28 AM
Yes, paralleling capacitors adds their capacitance.
