Bottlehead Kits
Crack
Left channel loud popping and crackling noise
bryan
1186
bryan
Newbie
June 14, 2021, 07:02:11 PM
Right channel audio is OK. The left channel does not produce any audio except loud pops and crackles. Voltages and resistances seem to be OK. Any way to fix this?
Paul Birkeland
Global Moderator
Hero Member
Re: Left channel loud popping and crackling noise
Reply #1 on:
June 15, 2021, 05:16:55 AM
Can you post the voltages you have and some photos of your build?
If the voltages are OK, you're likely looking at needing to reheat all of your solder joints.
bryan
Newbie
Reply #2 on:
June 16, 2021, 05:59:23 PM
I reheated the joints and that seemed to fix it for a while. The problem came back.
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
June 17, 2021, 06:21:13 AM
If you plug in a really cheap pair of headphones, then poke around with a wooden chopstick, you should be able to activate the popping noise by pushing on the loose joint.
Bottlehead Kits
Crack
