Bottlehead Kits
Eros Phono
Left Channel Out [resolved]
heavycowboy
5594
Paul Birkeland
Global Moderator
Hero Member
Re: Left Channel Out
Reply #15 on:
July 08, 2021, 07:38:39 PM
You could swap the C4S boards from side to side to confirm where the problem is with absolute certainty.
heavycowboy
Jr. Member
Reply #16 on:
July 09, 2021, 04:47:59 AM
Excellent idea. Will give that a shot this weekend and report back. Thanks again.
heavycowboy
Jr. Member
Reply #17 on:
July 12, 2021, 05:34:01 AM
Alright, so it's definitely the C4S board. Is there anything else on the board that could be causing the problem or are the transistors the most likely culprit?
Paul Birkeland
Global Moderator
Hero Member
Reply #18 on:
July 12, 2021, 06:27:44 AM
Generally you would expect to find a shorted transistor, like an MPS4250 with two legs that read as being almost 0 ohms on your meter, or that beep if your meter has a continuity beep.
heavycowboy
Jr. Member
Reply #19 on:
July 12, 2021, 11:15:42 AM
It was a blown MJE350. Sourced one from an old Seduction. Everything works as it should now. Thanks again for all your help.
Bottlehead Kits
Eros Phono
