Problems persist
Knightstick · 1788
Offline Knightstick
on: July 07, 2021, 12:32:42 PM
Hello all. I have gone through the wires on my crack from the power input to the transformer, and reflowed all joints. I also checked and reflowed all green wire terminals. The amps still doing the same thing. It will play for about 20 minutes then both tubes go out. I then unplug it, and plug it back in about 5 minutes later and the same cycle begins again. Seems like some kind of issue with heat. Any help would be awesome! Thanks in advance.
Adam
Offline kgoss
Reply #1 on: July 07, 2021, 03:09:36 PM
Post pictures especially around the heatsink. If you did not install that properly it might not becdoing its job. Also do a voltage check when the amp stops working. The problem seems repeatable.
Ken Goss
Offline Knightstick
Reply #2 on: July 07, 2021, 03:25:21 PM
Thank you for your response! I can definitely do some voltage checks but I haven't installed the speedball. It's still the stock crack. It wouldn't be the transformer would it? As long as that isn't gone I'm considering breaking it all down to do a better job.
Adam
Reply #3 on: July 07, 2021, 04:02:04 PM
You need to do voltage checks once the amp has powered itself off.  In particular the DC voltage at terminal 2 would be good to know.  It will either be 0V or close to 200V when the tubes aren't glowing.
Offline Knightstick
Reply #4 on: July 08, 2021, 04:35:04 AM
I got up this morning, and turned my amp back on. It has been running for approximately an hour and a half, and it sounds good. The only thing I did was to turn the power off yesterday when the tubes went out, and turn it on today. I suppose I got some cold solder joints? I did do a very poor job with soldering and rushed the build against wise advice.
Adam
Reply #5 on: July 08, 2021, 06:22:41 AM
Yes, I suspect you have a wire that either isn't captured by solder, or a cold joint.
Offline Knightstick
Reply #6 on: July 08, 2021, 06:48:26 AM
Thanks for your help sir! :)
Adam
