BeePre 2 Power Transformer Input Wiring
rover · 2919
Offline rover
on: July 13, 2021, 09:32:04 PM
The nominal voltage for Australian households is 230 volts
After wiring the PT to suit 230VAC, do pages 31 thru 34 still apply as instructed?
Offline Toobuzz
Reply #1 on: July 14, 2021, 02:46:34 AM
Hi!  Yes, you still need to build the High Voltage power supply on pages 31-34 as this provides the rectification (AC to DC) for the high voltage part of the circuit.
Sam
Offline rover
Reply #2 on: July 14, 2021, 11:12:23 AM
I know these stages still apply, but only double checking on config due to different voltage input and may have worded the question wrong.
Thanks Sam
Reply #3 on: July 14, 2021, 12:47:12 PM
On page 25, there is a powerline voltage test.  What voltage did you measure?
Based on that voltage, you can determine which wiring configuration to use for the primary of the power transformer, then we have you test the power transformer (which also helps to know that the correct line voltage configuration was chosen), then you move on with the build.
