Manual - Page Numbers
Ivan303 · 8446
Offline Ivan303
on: July 27, 2021, 08:28:16 AM
Really could use page numbers.
My printer jams about every 5-10 pages when printing double sided, so getting pages out of order is a big deal.  Especially when there are so many (70+)and they mostly look alike at first glance.
Think I have it all done right but will have to check against the .pdf viewer and will mark them manually.
The S.E.X amp manual did have page numbers and it was REALLY important as I went through each page, marking off as I completed a task and frequently had to go back to double check my work more than a few times.
Reply #1 on: July 27, 2021, 09:29:36 AM
This is the MonAmour forum, and so I am assuming you are talking about the MonAmour assembly manual. I just opened the pdf of the current manual in our dropbox (4-22-20) and the pages are numbered. Can you tell me what date your manual version says?
Offline Ivan303
Reply #2 on: July 27, 2021, 09:38:54 AM
MonAmour_Manual_04-22-20-ynta1r.pdf
Could it be my version of Adobe?  Don't see anyplace within my version of Adobe to add page numbers.
Don't recall having this problem with the S.E.X amp manual?
Offline Ivan303
Reply #3 on: July 27, 2021, 09:44:10 AM
AAAAAAAND, it's my printer or Adobe as the are on the .pdf I just downloaded from the email a second time.
Maybe try printing with a different setup?
Reply #4 on: July 27, 2021, 09:49:11 AM
Or maybe check that scale is set to Fit to Paper in the printer settings.
Offline Ivan303
Reply #5 on: July 27, 2021, 09:50:12 AM
Yep, printer set to 'actual size' was cutting off the bottom with the page numbers.
Set to 'fit to page' and the page numbers are there.
DUH!
OK, will print again with 'best quality' for better picture resolution.
Thanks.
