6dn7 with broken key on bottom; impedance switch positions
2Bornot2B · 3745
Offline 2Bornot2B
Please excuse me if this has been discussed before, I tried searching for an answer and did not get a reference. I purchased a used SEX 2.1 (I think, it has CC4 and impedance switch) and the tubes supplied had the key on the bottom of the base broken off. The seller suggested just trying various positions, I do not believe that is something I am comfortable with without some input from the forum.
Secondly, would someone share the positions for the impedance switch, I did not get a manual with the purchase.
Thanks in advance.
Bob
boB
Offline Thermioniclife
Reply #1 on: July 27, 2021, 11:04:53 AM
Yeah do not try to guess, if the whole key is broken off you can use these.
https://www.tubesandmore.com/products/keyway-replacement-piece-octal-tubes
The heater pins are 7 and 8, and these are the only 2 pins that have continuity so do search regarding tube pin numbering
and press the new key on so the key is in between pins 1 and 8
Reply #2 on: July 27, 2021, 11:10:33 AM
I realize that my reply is somewhat cryptic at best.
go to this link and it makes it clear. use a meter set to ohms and the only 2 pins that show continuity are pins 7 and 8
then it will be obvious what to do.
http://tdsl.duncanamps.com/show.php?des=6DN7
Can't help with the impedance switch.
Offline 2Bornot2B
Reply #3 on: July 27, 2021, 12:15:19 PM
Thanks that will get me started.
boB
Reply #4 on: July 27, 2021, 12:29:21 PM
You can mark the base of the tube between pins 1 and 8 and be careful to align the line up with the keyway on the tube socket.
And no need for the replacement key.
Reply #5 on: July 27, 2021, 01:06:14 PM
If it's the stock impedance switch (no longer in production) then the switch positions are marked on the printed circuit board. With the writing right side up,.
Both switches up = 32 ohms
left switch down, right up = 16 ohms
left up, right down = 8 ohms
both down = 4 ohms
The third switch selects balanced outputs or unbalanced outputs
Offline Adrian
Reply #6 on: July 27, 2021, 01:22:03 PM
Yep, I did this with the broken pin on a 6080.
Adrian C.
Offline Tubegopher
  • Don Palmer
Reply #7 on: July 27, 2021, 02:10:23 PM
Bob, I agree with Thermioniclife (hope I spelled that right) that you can just mark in between the 1 and 8 pin on the base of the tube and then line it up with the keyway on the socket.
However, I do have a bunch of the guide pin repair pins and would be happy to mail you one if you want to install it. It just makes it easier in the future if you remove the tube for any reason.
You can send me a private message to my email if you want one. I don't know why the envelope display does not show up, but if you place the mouse on the MSN "butterfly" and leave it there a few seconds, my email address will pop up.
Regards,
Don (Tubegopher)
« Last Edit: July 27, 2021, 02:20:57 PM by Tubegopher »
Offline 2Bornot2B
Reply #8 on: July 28, 2021, 03:05:31 AM
Thanks to all the help is very much appreciated.
Bob
boB
