Bottlehead Kits
Crack
Speedball large board voltage reading slightly high [resolved]
andrzej.suski
1832
andrzej.suski
Newbie
August 28, 2021, 05:29:49 AM
Hi,
I just installed the speedball upgrade. The small board works beautifully. The voltage check on the bigger board is around 115V for OA and OB. That's 15% higher than the specified range - is it a problem?
Thank you so much in advance!
Last Edit: August 28, 2021, 05:39:20 AM by Paul Birkeland
Paul Birkeland
Global Moderator
Hero Member
Re: Speedball large board voltage reading slightly high
Reply #1 on:
August 28, 2021, 05:31:33 AM
If they are both consistent that's unlikely to be an issue. These voltages can appear to be a bit higher of the OA/OB voltages on the small PC board are also a little high, or if the 6080 you're using has very high emission.
andrzej.suski
Newbie
Reply #2 on:
August 28, 2021, 05:32:45 AM
Excellent news!
Thank you!
Bottlehead Kits
Crack
