Bottlehead Kits
Mainline
Resistor ID help
Resistor ID help
Markkr
3366
Markkr
Full Member
Resistor ID help
August 28, 2021, 05:01:18 PM
Page 31, second step asks for a 220K ohm 1w resistor (red,red,yellow, gold) for the R4 position. The closest resistor I have in my kit is (red,red,brown,gold) and it measures 216K ohm. Is this the correct resistor for R4? (Maybe its just a typo in the instructions)
Paul Birkeland
Global Moderator
Hero Member
Re: Resistor ID help
Reply #1 on:
August 28, 2021, 05:15:11 PM
Red, red, yellow, gold is 220K. If it's 1% off, it will measure around 217K, and there's also meter tolerance, so no worries there.
Markkr
Full Member
Reply #2 on:
August 28, 2021, 05:21:11 PM
Thanks Paul, I dont have a red,red,yellow,gold… I only have red,red,brown,gold which measures 216
I’m starting to feel bad about asking Eileen to send me parts, (this is the third missing part)
Last Edit: August 29, 2021, 02:53:26 AM by Markkr
FS
Full Member
Reply #3 on:
August 28, 2021, 06:31:44 PM
So what's the problem? You need a 220K resistor, and the one you have measures 216K.
Apparently, you have a red/red/yellow/gold resistor...you just can't tell yellow from brown...
I would feel bad, too, if I were to ask Eileen to replace that part...
Markkr
Full Member
Reply #4 on:
August 29, 2021, 03:02:22 AM
DISREGARD, I just figured out my problem...
I was building last night while too tired.
I retraced the previous few steps on the Bias board, and yes, apparently I used the wrong resistor for a previous step because I couldn't tell the difference between yellow and brown
Paul Birkeland
Global Moderator
Hero Member
Reply #5 on:
August 29, 2021, 06:22:17 AM
I'm glad you caught that. Putting the carbon film resistor in that position and turning the amp on would do quite some damage!
Bottlehead Kits
Mainline
Resistor ID help
