Bottlehead Kits
Stereomour II
Stereomore and speakers
Knightstick
3068
Knightstick
Full Member
September 01, 2021, 01:36:42 PM
Hello, I have just purchased the Stereomore 2. I'm wondering if it can power 6 ohm speakers? I see it says 8, 4, and 2 ohm so was just hoping my 6 ohm speakers will work. Thanks in advance for any replies.
Adam
Global Moderator
Hero Member
Re: Stereomore and speakers
Reply #1 on:
September 01, 2021, 02:11:53 PM
They should work well, using either the 4 ohm or 8 ohm wiring. The 8 ohm will give a bit more power; 4 ohms will give a bit less distortion and better damping factor. I recommend trying both to see which works better with your speakers and your music.
Let the amp settle in for 50 hours of music before making judgements, as the sound will change a bit over that initial period.
Bottlehead Kits
Stereomour II
