New meters
Thermioniclife · 31512
Offline Thermioniclife
on: September 08, 2021, 03:13:17 PM
So I had problems with both the meters, I ended up removing them and replacing them. I partially recessed them and they work great. Dead nuts on with actual measurement.
My Spidey senses tell me someone else may do something similar.
I mounted them facing the 2a3 because I am working on a vertical mounting system keeping the footprint as narrow as possible.
The amps sound very good.
Offline debk
Reply #1 on: September 08, 2021, 11:26:54 PM
I am planning on doing the same thing, except I will mount them to face forward.  I will post a picture when I make the modification
Debra K
Eros 2Phono amp
BeePre2, Psvane ACME 300b
Kaiju, Linlai Elite  300b
Rega P6 Ania Pro cartridge
Roon Nucleus
MHDT Labs Orchid DAC
Jager speakers
Offline debk
Reply #2 on: September 09, 2021, 02:59:34 PM
I added the digital panel meters to my MonAmour amps.  Simple to do and I like the look.
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Offline debk
Reply #3 on: September 09, 2021, 03:00:19 PM
and the top side
Debra K
Eros 2Phono amp
Roon Nucleus
Jager speakers
Reply #4 on: September 09, 2021, 03:19:57 PM
Looking good Deb, I have one recessed and one full height, still haven't decided yet, I'm fickle.
My Spidey senses were correct, It's funny how great minds think alike.  ;D
Offline johnsonad
Reply #5 on: September 09, 2021, 04:25:25 PM
Great idea! I like both versions!
Reply #6 on: September 09, 2021, 04:54:07 PM
Thank you Aaron.
Offline Ivan303
Reply #7 on: September 10, 2021, 04:01:47 AM
Dose Bottlehead have an 'official' fix, or is this it?
If so, does it come with instructions?  Where to get the meters?
Both of my meters bit the dust as well, and within just a few hours of operation.  No rush, just curious.
TIA
Reply #8 on: September 10, 2021, 04:43:00 AM
What is really odd about this is that I put a few dozen of these into service in various projects before we ever released them in a kit.  One out of about 25 ended up being sticky but started working properly with a whack.  Some of these meters have been operating daily for five plus years now without a hiccup.
It would help if we could get some of these back to see what's going on with them.
Reply #9 on: September 10, 2021, 09:20:25 AM
Hi PB, I will send my meters back to your attention.
Offline Ivan303
Reply #10 on: September 13, 2021, 05:00:45 AM
Hi PB
Should be able to send them back.
Do I need to keep those four little resistors in the circuit?  Send them back with the meter and short around them?
Replace them with new little resistors?
Wait for replacement meters?
How should this work?
Be happy to do it any way that makes sense for you.
Reply #11 on: September 13, 2021, 06:48:07 AM
The latest meters we have been getting are already compensated, so the resistors aren't necessary any longer.
Offline Ivan303
Reply #12 on: September 13, 2021, 11:07:41 AM
Hi Paul,
As those four little parallel resistors are in series with the 2A3 cathode, exactly how does that work, exactly?
Cathode current goes through the new meter?
Meter across some other part of the circuit?
Are you sending out new meters with instructions?
Reply #13 on: September 13, 2021, 12:56:50 PM
The paralleled resistors set the meter to read the scale that's displayed on it.  With no resistors it will go to 100mA with 1mA of current.  The new meters have this built into the inside of the meter.
DC current goes through the cathode resistor(s) and meter,  AC current not so much.
We are not sending out the meters with instructions.  You just replace old with new.
Offline Ivan303
Reply #14 on: September 14, 2021, 04:49:33 AM
Sounds like I should wait until I receive replacement meters before I return the old ones???
