Static noise
Knightstick · 2960
Offline Knightstick
on: December 13, 2021, 04:00:18 AM
Hello, my amp is making a static noise for about 3 or 4 seconds with a hum that completely goes away. Doc informed me the hum was normal but does that hold true with the static also. The amp performs great but wanna make sure before I decide to upgrade. Thanks in advance for any insight.
Adam
Reply #1 on: December 13, 2021, 05:21:50 AM
Do you mean it makes the static noise for three seconds only once? Or does it repeat? If it repeats it could be a router or something else in your environment causing interference.
Offline Knightstick
Reply #2 on: December 13, 2021, 06:05:54 AM
It only lasts for a couple seconds then it dissappear and sounds great. It only happens during the initial startup. So only once.
« Last Edit: December 13, 2021, 06:07:26 AM by Knightstick »
Adam
Reply #3 on: December 13, 2021, 06:26:19 AM
If it goes away in a few seconds and does not come back I would not be concerned.
Offline Knightstick
Reply #4 on: December 13, 2021, 06:36:54 AM
Thanks doc!
Adam
