News:
May 20, 2022, 11:40:23 PM
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Bottlehead Kits
Crack
Would like to upgrade
Pages: [
Author
Topic: Would like to upgrade (Read 240 times)
bucketofguts
Jr. Member
January 07, 2022, 12:13:50 PM »
I put a new Audio Note Pot in my Crack.. Now I would like to try a pair of Audyn Cap Q4 100uF 400V MKP Metalized Polypropylene Foil Crossover Capacitors. It it as simple as replacing the stock capacitors withe the new. If that is the case i can do that. If not could someone steer me in the right direction. Thanks in advance.
Logged
Paul Birkeland
Global Moderator
Hero Member
Re: Would like to upgrade
Reply #1 on:
January 07, 2022, 01:51:45 PM »
Yes, it is that simple. Those big caps will fit much, much more easily in a Crack-a-two-a and there are mounting points so you can secure them to the chassis plate.
Logged
bucketofguts
Jr. Member
Reply #2 on:
January 07, 2022, 02:41:52 PM »
I am sipping the cool aid with a little bourbon. In Doc B’s words “…for the stock Crack circuit the two easiest improvements after Speedball are film output caps and a better attenuator.” Thank you very much for your reply. I plan to keep Bottlehead rolling in many ways. I need a new Turntable preamp and have a few PQ 6922 valves so ........ I am saving my $.
Logged
bucketofguts
Jr. Member
Reply #3 on:
January 20, 2022, 02:18:28 PM »
I i just finished putting the bigger film saps in. I say that they make a the Crack sound better. I spent $74.00 bucks and think that it was $ well spent. I took out my Tung-Sol 5998 and my Sylvanlia 6SN7GT both vintage and put in a Thomson 6080WA and one of my RCA Clear Top and gave a listen. Sounds like it grew bigger you know. I am going to have a beer now listen to a old CBS Records of Aja. Many thanks to all that have helped along the way. I put the Caps both with the names and values towards the headphone jack. I saw somewhere that they go in a certain way due to the way the are constructed? I have seen them installed both ways. Maybe someone will jump in. Might have to turn mine around.
Logged
Paul Birkeland
Global Moderator
Hero Member
Reply #4 on:
January 20, 2022, 02:30:02 PM »
Inner and outer foil in that position is not at all critical.
Logged
bucketofguts
Jr. Member
Reply #5 on:
January 20, 2022, 07:03:52 PM »
Thank you!
Logged
Pages: [
Bottlehead Kits
Crack
