Balanced/single ended switch
RestoredSparda · 2698
Offline RestoredSparda
on: January 08, 2022, 06:13:05 PM
Sorry for all the questions.  :o
Is it possible to miss wire the balanced/unbalanced switch backwards?
I wanted to make sure it's working correctly. Basically when I am using 1/4 jack the amp is much louder when switched to unbalanced (the correct setting). It is quieter when switched to balanced.
When using the balanced XLR connector I notice zero difference in volume when switching between balanced and unbalanced switch.
Thank you!
« Last Edit: January 08, 2022, 06:20:54 PM by RestoredSparda »
Reply #1 on: January 09, 2022, 06:13:19 AM
What you are describing is normal operation.
Reply #2 on: January 09, 2022, 06:55:21 AM
Cool. Thank you.  I went through the instructions and all looks good.
