Moreplay intermittent static on the left channel. (Solved)
TiberKing · 2103
Offline TiberKing
So I completed my first Bottlehead Moreplay kit a couple weeks ago. It has been wonderful until today. I have noticed static on the left channel. All voltage checks passed, and swapping tubes does not fix the problem. Just curious if there are any common problem areas I should start with before I go too deep. It only seems to show up if the volume is above 9 O’clock on the dial. Thanks in advance for any help with this issue.
« Last Edit: February 12, 2022, 06:55:58 AM by TiberKing »
Reply #1 on: February 12, 2022, 06:13:25 AM
I would reflow all of your solder joints.
Offline TiberKing
Reply #2 on: February 12, 2022, 06:54:53 AM
That was the ticket! It was the left input RCA jack. thank you so much for the prompt reply!
