No output
Knightstick · 3687
Offline Knightstick
on: February 15, 2022, 12:09:57 PM
Hello I have been using my Stereomour for a couple months when I decided to move it. I reconnected my speakers it stopped playing correctly on the right channel. I checked everything to see that if there wasn't a problem before the amp. I then turned the amp on again and both channels were dead silent. I also tried different rca inputs that didn't work either. I've checked over my solder joints and they seem okay. Any help would be great.
Adam
Reply #1 on: February 15, 2022, 12:12:27 PM
Make sure the spade lugs on your speaker cables are making contact with the metal of the binding posts.
« Last Edit: February 15, 2022, 01:04:24 PM by Doc B. »
Offline Knightstick
Reply #2 on: February 15, 2022, 12:24:33 PM
I've done that and there is no change. Also I connected another amp to speakers and it there's output.
Adam
Reply #3 on: February 15, 2022, 12:55:28 PM
I would perform the voltage checks in the manual and let us know any that are off.
Offline Knightstick
Reply #4 on: February 16, 2022, 01:34:17 PM
Thank you so much for your help. I solved the issue.
Adam
Reply #5 on: February 16, 2022, 01:35:55 PM
Don't leave us hanging?  What happened?
Offline Knightstick
Reply #6 on: February 16, 2022, 02:26:07 PM
Sorry bout that. It was something with how it was connected outside the amp. All my voltages checked out
not sure what happened, only.that I put it back together and it works great again.
Adam
