Bottlehead Kits
Legacy Kit Products
Smash
Smashup Voltage [resolved]
1026mind
160042
3
4
Paul Birkeland
Global Moderator
Hero Member
Re: Smashup Voltage [resolved]
Reply #30 on:
February 22, 2022, 11:05:33 AM
In your build where does the power supply connect to the chassis?
1026mind
Jr. Member
Reply #31 on:
February 22, 2022, 11:31:42 AM
everything goes to a grounding post.
Paul Birkeland
Global Moderator
Hero Member
Reply #32 on:
February 22, 2022, 11:37:23 AM
You have umbilicals in your build, so is each chassis plate connected through the umbilical?
1026mind
Jr. Member
Reply #33 on:
February 22, 2022, 11:51:27 AM
they are two umbilicals, one for the filament of the 4p1l's that is two wires and the other has 3 , one is ground and the other two are both 150v, one for each channel .
Paul Birkeland
Global Moderator
Hero Member
Reply #34 on:
February 22, 2022, 11:56:33 AM
so you have each chassis plate connected through the audio ground?
1026mind
Jr. Member
Reply #35 on:
February 22, 2022, 12:19:15 PM
yes Sir
Paul Birkeland
Global Moderator
Hero Member
Reply #36 on:
February 22, 2022, 12:41:18 PM
That is a potential source of noise. Ideally you would have the chassis plates connected together through their own wire in the umbilical and that would be hard grounded to the E lug on the IEC power entry module, then the audio/power supply ground would run separately and you would put the antiphase diodes in the amp section between the audio ground and the chassis.
1026mind
Jr. Member
Reply #37 on:
February 22, 2022, 01:02:30 PM
audio ground would be the part where the RCA are connected to the ground?
1026mind
Jr. Member
Reply #38 on:
February 22, 2022, 01:04:25 PM
never mind my last comment
1026mind
Jr. Member
Reply #39 on:
February 22, 2022, 02:44:10 PM
just finished and its still a little buzz
1026mind
Jr. Member
Reply #40 on:
February 22, 2022, 03:17:19 PM
now I don't know if you noticed but I don't have the pots nor the attenuators at the input, I'm just using the volume from my OPPO player.
could that be the reason for the little buzz/noise?
Paul Birkeland
Global Moderator
Hero Member
Reply #41 on:
February 22, 2022, 04:11:40 PM
What is at the input of the pre? Just jacks wired to the grids of the 4P1L?
1026mind
Jr. Member
Reply #42 on:
February 22, 2022, 05:00:54 PM
yes
Paul Birkeland
Global Moderator
Hero Member
Reply #43 on:
February 22, 2022, 05:15:27 PM
You should have a 47K resistor from grid to ground on each 4P1L. If you pull the RCA cables, the grid has no ground reference and that can cause damage to the 4P1Ls.
1026mind
Jr. Member
Reply #44 on:
February 23, 2022, 03:49:52 AM
when I purchased the smashup upgrade I got the smash quiet to. I want to built it but I have do diagram. Is it possible to get one?
Thank you! Btw I'm waiting on the attenuators, they are in the mail from France
3
4
Bottlehead Kits
Legacy Kit Products
Smash
