Bottlehead Kits
Kaiju Stereo 300B amp
Failed Voltage Test Page 47
ArtnShit
12940
ArtnShit
Full Member
Re: Failed Voltage Test Page 47
Reply #15 on:
February 19, 2022, 08:02:53 AM
The fuse is ok! Any other ideas about the sparks or the drop in voltage? I can double-check again if that's the move, too.
Sorry about all the questions and thank you for talking me through this.
a&s
Paul Birkeland
Global Moderator
Hero Member
Reply #16 on:
February 19, 2022, 08:03:08 AM
Yes, double check the voltages.
ArtnShit
Full Member
Reply #17 on:
February 19, 2022, 08:12:11 AM
Double checked, everything is in the proper ranges now! Weird. Should I be concerned about that spark? I have a feeling I connected two metal things that weren't meant to touch, but everything is going fine now?
Thanks again for your help.
a&s
Paul Birkeland
Global Moderator
Hero Member
Reply #18 on:
February 19, 2022, 08:17:01 AM
If everything is OK now, I wouldn't be too worried about the spark. If your meter probes have a lot of exposed metal on the tips, you can wrap tape around all but the last tiny bit of metal to offer some additional protection.
Bottlehead Kits
