No sound coming from the left, lots of static from the right [resolved]
CrackNoob · 2136
Offline CrackNoob
Hello fellow Cracks,
I'm getting no sound coming from the left and lots of static coming from the right. I checked the LEDS, D2 on the large board is not lighting up and the LED on the crack A8. I tried reflowing all the joints to the small tube sockets and the connections for the speedball boards to the crack unit. Here are my result from voltage test:
Large Board:
OA - 194
OB - 72
G- 0
B -204
Small Board:
OA - 4.1
OB-77
Hope you guys can help.
« Last Edit: February 20, 2022, 06:46:32 AM by Paul Birkeland »
Reply #1 on: February 19, 2022, 06:55:05 AM
Were the voltages OK when you installed the small board?
Offline CrackNoob
Reply #2 on: February 19, 2022, 07:52:28 AM
My built was operational prior to not being used for a good year. So yes the voltage was good when I had it working.
Reply #3 on: February 19, 2022, 07:54:01 AM
If the amp was operational and now is not, this would tend to suggest there's a flaky solder joint or loose connection making its presence known.
Offline CrackNoob
Reply #4 on: February 19, 2022, 08:31:22 AM
Is it possible one of the transistor is blown? I checked all the joints, and everything looks pretty solid.
Reply #5 on: February 19, 2022, 09:04:05 AM
Why would a transistor be blown?
Is the keyway still present in the base of your 6080 tube?
Offline CrackNoob
Reply #6 on: February 20, 2022, 06:35:54 AM
I went through all the wires again, even though all of joints were solid, I found one red wire that was about to break off, I'm assuming during the stripping process i went a little to hard on it. I replaced it and solder, everything works great now. Thanks!
Offline CrackNoob
I think I spoke too soon, maybe I had the input jack half way in which gave me both sounds on the left and right. But now when I plug in the jack all the way in it doesnt give me sound on the left side. The static went away though. One problem after another.
« Last Edit: February 20, 2022, 07:03:49 AM by CrackNoob »
I would recheck your voltages and post back any that aren't correct.
Offline CrackNoob
Voltage seems to be close to the recommended range after fixing the red wire going to the power.
Large Board:
OA - 140
OB - 120
G- 0
B - 202
Small Board:
OA - 80
OB- 80
« Last Edit: February 20, 2022, 12:53:20 PM by CrackNoob »
I would post some build photos, it's possible that there's something we can spot.
