Crack finished
hasafraker · 28400
Reply #15 on: January 09, 2011, 04:38:05 AM
Paul,
Thanks, I have considered an arrangement like one of WardsWeb's FP 2s.  This thread:
http://www.bottlehead.com/smf/index.php/topic,1325.0.html
The inputs and outputs are on the back, the volume & selector in front.  I have no tools for the woodwork or metal work he does.  But for me pretty isn't necessary, the sound is everything.  I'm saying I will probably move the inputs and outputs but it won't be pretty.
See my thread "Bud Tugly Seduction, Matches Bud Tugly FP 2" :
http://www.bottlehead.com/smf/index.php/topic,313.0.html
Offline spear321
Reply #16 on: January 09, 2011, 06:31:45 AM
Know exactly what you mean my wood working and metal working skills are about zero too!
My WAD KIT6550 started out looking fairly neat inside, but changing the power supply to accomodate 2 x15uF 650V film capacitors and upgrading the other caps put paid to that, now looks like a rats nest underneath, sounds good though, had it from 2002 so must be fairly happy with it.
How come the best sounding capacitors usually tend to be the biggest, makes getting it all back in the case tricky.
Paul
Paul Batstone (UK)
Astin Trew 3500+ CD player,Rotel Tuner, Pure i20 Dock into muse 4 x TDA 1843 DAC (non oversampling)World Audio Design KIT6550 Amplifier, KEF Q500 speakers, Michell Syncro TT, Bottlehead Crack, Sennheisser HD600
Offline hasafraker
    • Hasafraker Blog
Reply #17 on: January 09, 2011, 06:42:52 AM
I haven't really found any right angle RCA jacks that aren't premade and then you connect regular patch cables to. If I could find some with solder tabs in them I'd be inclined to build a few sets for my gear with top mounted RCA jacks, most of my stuff has the typical rear exit connectors.
@Granger, I like the cup hooks idea I'll bet that works really well too.
as long as it sounds good, who cares?
Main system; AT-LP120-USB Turntable w/AT440MLa, Bottlehead Reduction Phono, Decware ZSP1 Preamp, Pass Labs ACA Monoblocks, PSB Alpha B1's, MartinLogan Dynamo 300 sub. Bottlehead Crack w/Speedball, Interconnects and stands all DIY.
Offline paulw
  • 2A3 = Music
    • My Hobby Site
Reply #18 on: January 09, 2011, 09:25:31 AM
I know Switchcraft still supply R/angle RCA's as do Audioquest (link) the Switchcraft are quite poor quality but I've not seen the Audioquest in the flesh.
Paul
Paul Williams
Acoustic Signature Challenger (with 3 arms) Entre SUT+Seduction, Smash(out) & Quickie(in again), Paramour II's, 7 Pi Corner Horns or Quad 44, Quad 405-2 & Videoton Minimax GB3.
Offline hasafraker
    • Hasafraker Blog
Reply #19 on: January 09, 2011, 10:05:04 AM
actually I had just found the switch craft ones, not something I've looked for before now, interesting, I might have to pick up some and see what I think. Thanks for the info Paul :)
Reply #20 on: January 09, 2011, 02:20:09 PM
Paul
Paul, I appreciate it but those are plugs, I was thinking jacks since I don't want to rewire my cables.
Actually my situation is OK for the inputs to be vertical since they come in from the back of the cabinet above my FP 2.  My outputs would benefit from being horizontal because my amps are in front of my FP 2.
Offline ToolGuyFred
Reply #21 on: January 11, 2011, 02:05:17 AM
It was not always so. I'm sure I'm not the only one to mourn the passing of Black Gates. These were generally rather smaller than their film counterparts.
I unsuccessfully tried to get some BGs for my ParaSEX amps last year but they were rarer than an honest politician.
John
Amateur Audiophile and Backstreet Boffin.
Original Foreplay with C4S + Sweet Whispers
ParaSEX amps with MQ nickel-cored outputs
Factory-built Lowther Acousta 115s with silver-coiled DX3s, wired in DNM solid-core
KEF active sub (help for the last couple of octaves).
Bottlehead DAC on batteries.
Offline HF9
  • Zynsonix.com
    • Zynsonix.com
Reply #22 on: January 11, 2011, 07:58:18 AM
Great Work!! I really like the ZSP-1 in your album too.
Grainger,
I know these aren't direct solder but they are decent quality:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2F41IZOeeISrL._SL500_AA300_.jpg&hash=04001c24b6f24adaf7ab04da89eb3632232ef743)
http://www.amazon.com/AudioQuest-90-degree-adapter-female/dp/B000J38HZ8
With some unique building, you may be able to incorporate the PCB mount Cardas RCAs:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.cardas.com%2Fimages%2Foem%2FFEMALE_RCAS%2FGRFA_DBL_PRT_G.jpg&hash=3f85b4100cc3f6bef74cd0ae0c679e70807cea9d)
http://www.cardas.com/content.php?area=oem&pagestring2=Female%20RCAs&pagestring=Female%20RCAs+%28closeup%29&content_id=6&part_id=159
...probably more trouble than it's worth though ;)
« Last Edit: January 11, 2011, 08:00:34 AM by HF9 »
Reply #23 on: January 11, 2011, 08:26:16 AM
The 90 degree adapter looks pretty robust.  I'll have to consider them.  I have a one in two out set of those from my Creek remote volume control.  They feed my sub and Paramours.
Offline hasafraker
    • Hasafraker Blog
Reply #24 on: January 11, 2011, 08:38:25 AM
Hey HF9 thanks for the good info, those Audioquest 90's look pretty stout. The ZSP1 was an adventure in frustration for a while but it sounds really nice :)
Reply #25 on: January 11, 2011, 01:37:34 PM
I think we have a batch of right angle adapters somewhere. They are not Audioquest, but they work pretty well. I'll see if I can find them.
Offline dstrimbu
Reply #26 on: January 13, 2011, 10:22:45 AM
If Doc can't find his 90s, I can vouch for the quality of the Audioquests... they are very heavy, super construction both ends (M & F).  Bought them on Amazon for $5 each... I have 4 of them.
Offline hasafraker
    • Hasafraker Blog
Reply #27 on: January 15, 2011, 01:32:35 PM
Ok, I swiped my wife's camera and uploaded some better pictures of my Crack. http://www.flickr.com/photos/28861421@N02/
Any luck finding those connectors Doc?
