Freshly completed build - questions re: hum and blown fuses in power amp
cacofonix · 7180
Offline cacofonix
Hiya
Just completed my moreplay build and was wonderful to hear the results of my efforts
I've got a couple of things that I could use some help with.
Questions (beginner knowledge level)
1. I've got some speaker hum coming from both channels and I've tried a couple of things to diagnose per the manual
DAC (peachtree) -> Krell 400xi power amp -> speakers == no hum
DAC ->  Moreplay -> power amp -> speakers == hum
So its either the moreplay or a faulty monoprice rca cable causing the possible ground loop?
I've also tried plugging in the moreplay into my main system with McIntosh power amp and its less obvious but still there.
I found 2 spots where I'd forgotten (missing instruction?) to solder the ground lugs near the input jacks - figuring this might have something to do with it - but soldering those did not help alleviate the noise.
Are there any suggestions on how to systematically approach this - can i use my DMM to find the source of the noise?
2. (The more scary question) The fuse in the power socket bit of my krell power amp just blew for the second time. Unfortunately I dont remember the exact steps I took the first time - but this second time. I just powered up my equipment while testing the output RCA jack that usually goes unused
(note: powered up with left output jack being used = no blown fuse
          power up with the right output jack = blown fuse)
Would this be cause by short somewhere in the moreplay?
Now i need to buy more fuses before I can listen to it again and I'm a little worried about plugging the moreplay in.
The second may be the reason for the first question. I'm looking for guidance on how to diagnose both issues.
(See attached pics of my wiring at the i/o section)
Offline Thermioniclife
Is the 2.2uf coupling cap shorted placing dc on the input of the Krell?
Can we see some overall build photos of your Moreplay? There should be absolutely no noise at all with the Moreplay turned all the way down.
Did your Moreplay pass all its voltage checks?
Offline cacofonix
Thanks for helping!
Answers to questions
- The noise persists independent of volume level
- It did pass all resistance and voltage tests per the manual at the end. I should probably repeat them post making some fixes.
- @Thermioniclife - I dont know how to answer your question but I'm assuming that was for someone that knows what they're doing.
See attached photos of my completed build with some closeups
Let me know if those help and/or if i should take better pictures in better light
With the volume all the way down, the output of the preamp is a dead short, so any noise that you're getting at the power amp may be from an external source under those conditions.  Just to double check, with the volume all the way down, what is the DC resistance between ground and the center pin of each output RCA jack?
Offline cacofonix
The peachtree and the krell amp have been plugged in and working without noise for a while and the only explicit change I just made was plugging in my moreplay.
Removing the moreplay from the chain cause the noise to disappear (or at least get minimized to where I cant hear it?)
So you think that the moreplay may just be highlighting the noise from something else?
I will measure resistances like you asked and get back to you with results
Embarrassing question: When measuring DC resistance like you ask - do I need the unit powered up? My intuition says no - but I want to confirm before sending you erroneous results
No, you don't need the unit powered up.
Offline cacofonix
Resistance measurements with black MM lead attached to ground pin of IEC module
Output jacks closest to IEC module
R5 = 239.8
L5 = 239.8
Further from the IEC module
R4 = 23.1
L4 = 23.1
Tiny bit of ~ 0.1 fluctuation
Something you could try is temporarily wiring in a jumper wire across the 22R/UF4007s/0.1uF cap to hard ground the audio ground to the chassis.
Offline AB2KH
The two bare copper ground drain wires that attach to the independent ground lug tab do not look to me to be soldered properly.
Chris/AB2KH
Offline cacofonix
Thank you guys. Keep the suggestions coming ...
@Paul - trying to make sure I understand this
Quote
- The 22R/UF4007s/0.1uF bundle goes from 23L to 32L per instructions
- So you're saying to temporarily just attach some jumper wire on either side of that bundle?
- This would cause a hard ground of the audio ground?
Once I do this - what should I do to test? Check voltages? or plug into amp and cross fingers that it doesnt blow another fuse?
@Chris
Pretty sure I've soldered them but I'm plenty capable of shoddy work. So I will reflow / resolder those two to make sure
I would try it with the Peachtree first to see if the noise you're observing has gone away.
Offline cacofonix
ok - i followed your suggestions
Changes I made
1. Re-soldered 2 copper wires to ground lug per Chris
2. Temporarily connected bare copper wire across  22R/UF4007s/0.1uF bundle
3. Tried with just laptop and peachtree in chain
Macbook source (using headphone to RCA) --> ( R1/L1) Moreplay (both outputs) --> Peachtree aux in --> Speakers
No noise, no blown fuses, no fireworks
What do you suggest next? Try the original chain with the temp wire in place? (I bought 2 new fuses so I have 2 attempts :))
Macbook source (using usb) --> Peachtree DAC (use Pre out) --> (R1 / L1) Moreplay  --> Krell amp --> Speakers
Offline cacofonix
next test continuing from previous attempt
Changes
1. Original / desired chain
Keeping gain low I powered up and didn't get any blown fuses
However, the speaker hum / noise returned
Music played and volume and balance all seemed to work
So, it seems
Peachtree + Krell = no noise
Moreplay + Peachtree = no noise
Peachtree + Moreplay + krell = noise (however, no blown fuses this time)
Thats an improvement right?!
So - what next - what do I do with that temporary wire bypassing the 22R/UF4007s/0.1uF bundle?
I have found that for some components with two wire power cords, having a hard connection between audio ground and earth ground can be helpful (which is what that bypass wire is doing).
With the Moreplay driving the Krell, is there noise now with the volume pot turned all the way down?
