Bottlehead Kits
Crack
Heater Wiring
Heater Wiring
Hilts
1843
Hilts
Jr. Member
Heater Wiring
March 21, 2022, 05:20:28 AM
Here I am again
When connecting the heater wiring the manual states to connect terminal 7 and 9 of the transformer to B7 and B8 of the octal socket. As the the 2 wires are twisted together, it is hard to know which wire is which. Is there any order of which wire connects from the transformer to the octal socket. Ie terimal 7 to B7 or does it not matter what wire is connected to what?
Thanks.
mpeg2
Full Member
Re: Heater Wiring
Reply #1 on:
March 21, 2022, 05:27:35 AM
Usually, it doesn't matter which connection is made on the heater wires - but if you really want to follow the directions, use an Ohmmeter to figure out which wire goes to which terminal.
Rich
Paul Birkeland
Global Moderator
Hero Member
Re: Heater Wiring
Reply #2 on:
March 21, 2022, 05:50:45 AM
It doesn't matter which goes to which. (We would use two different wire colors if this was important)
Hilts
Jr. Member
Re: Heater Wiring
Reply #3 on:
March 21, 2022, 05:58:51 AM
Thanks gents 👍
Deluk
Sr. Member
Re: Heater Wiring
Reply #4 on:
March 22, 2022, 03:35:38 AM
As PB says but you can always mark one of the wires with a sharpie before you twist it. Don't rub off the mark while twisting.
Bottlehead Kits
Crack
Heater Wiring
