Hi Souter
I am waiting for my Crack so I am very interested when people have problems to understand what can go wrong with the kit. Please tell us when it will be resolved.
Do not give up, you are very close.
Hi Mr. Birkeland
Reference picture 232212.
The grounding point at the headphone is crucial if I undertand well:
The black wire coming from the right is the main ground.
All the connections at the top of the picture ( resistor, resistor, bare conductor) should be all soldered together including the main ground and the black wire going to the bottom to bring the ground to the big cathode resistors. What is the purpose of those resistors. Loads for the output tubes when there is no headphone connected?
Test point 2 and 4 are at 192V. Its looks very high according to your spec. Does Souter should change the primary taps on the power transfo?
