Bottlehead Kits
BeePre
Voltage Check
Voltage Check
Ivan303
2883
Ivan303
Full Member
Voltage Check
April 05, 2022, 12:52:26 PM
page 19 Voltage check
183.2 VDC on both pin 1 and 11?
Close enough to approximately 150 V?
Haven't put it back into the system.
Paul Birkeland
Global Moderator
Hero Member
Re: Voltage Check
Reply #1 on:
April 05, 2022, 12:53:24 PM
Yes, what you don't want to see is something super low compared to the 150V reference.
Ivan303
Full Member
Re: Voltage Check
Reply #2 on:
April 05, 2022, 01:05:22 PM
Great.
Have 124V on both plates (6 and 16) and about 12.5VDC on both cathodes so a whopping 112V across the 300B.
Will now listen.
Thanks!!!!!
Paul Birkeland
Global Moderator
Hero Member
Re: Voltage Check
Reply #3 on:
April 05, 2022, 01:05:56 PM
When you only need to swing a few volts at the plate, not a whole lot of plate voltage is required
Bottlehead Kits
BeePre
Voltage Check
