Preamp Headphone
reglys · 7311
Offline reglys
on: April 09, 2022, 03:21:36 PM
Hi
If we forget the 6.3 Vac voltage needed for the tube heaters, would it be possible to get enough DC voltage for the output tubes by rectifying 120 Vac powerline without a power transformer in a headphone preamp for instance.
Thank you in advance
Reply #1 on: April 09, 2022, 05:09:10 PM
This is universally accepted as an unsafe practice. It's like removing the brakes on a car to save weight.
Reply #2 on: April 11, 2022, 08:14:23 AM
They used to make radios like that in the 30s and 40s. They were called widowmakers for reason.
Offline Thermioniclife
Reply #3 on: April 11, 2022, 12:06:39 PM
Yeah. also called curtain burners. Many old tube radios have a built in resistance in the power cord that if replaced with a modern cord disaster is sure to happen. Also they were designed for 110 Vac.
Offline reglys
Reply #4 on: April 11, 2022, 12:26:04 PM
Yes I understand at that time they had plug with 2 prongs and they didn't care about the polarity and you could have a hot chassis.
However it is amazing when we see what Apple is doing with their tiny IPAD power supply . First time I used it in Paris, France during an oversea trip, I was sure this tiny power supply will blow out at 230 Vac.
Reply #5 on: April 11, 2022, 12:31:13 PM
You could certainly use a 6V wall wart to power your heaters.
