Resistance Checks [resolved]
thoven0215 · 17032
Offline thoven0215
on: April 28, 2022, 06:20:00 PM
When doing the resistance checks I noticed that all the checks on the left side of the board went ok, but almost everything on the right side measured as infinity. 15, 16, 17, 18, 36, 37, 39, 40 all measured as infinity. I reflowed the solder joints to no avail. What should be my next steps? Thanks
« Last Edit: May 09, 2022, 05:15:14 AM by Paul Birkeland »
Sihwan
Offline thoven0215
Reply #1 on: April 28, 2022, 07:07:12 PM
Here are some pictures.
Sihwan
Reply #2 on: April 29, 2022, 04:25:11 AM
When the manual says "attach", that means you need to physically attach a wire or component lead to a terminal strip.  Your build is very unlikely work if all those connections just pass through a terminal strip or tube socket and don't bend up at least, if not up and around the terminal.  You need to go through your build and do that to every single connection before thinking about turning it on.
Terminal 5 wires to terminal 8.  Terminal 8 wires to terminal 13.  Terminal 13 wires to terminal 16.   These wires all appear to be there but if there are soldering issues that could be discovered in the resistance checks.
Reply #3 on: April 29, 2022, 05:09:55 AM
Offline thoven0215
Reply #4 on: April 29, 2022, 01:54:21 PM
I attached them and soldered again, but I still get infinity for the same terminals.
Sihwan
Reply #5 on: April 29, 2022, 02:18:25 PM
They are wired together.  Wires are 0 ohms.  If they are wired together, you'll get zeroes where you're supposed to.  If you have flaky/broken connections, you won't get your zeroes.
Offline thoven0215
Reply #6 on: April 29, 2022, 03:09:47 PM
I'm not exactly sure what you mean. I get all the 0s where I am supposed to, it is just that I get infinity for a lot of places that shouldn't measure at infinity.
Sihwan
Reply #7 on: April 29, 2022, 03:20:12 PM
16 and 18 are supposed to be zero and you listed them as infinity.
Offline thoven0215
Reply #8 on: April 29, 2022, 03:46:52 PM
I am very confused on how this happened but after measuring again everything just resolved itself. Thank you for your help Mr. Birkeland.
Sihwan
Offline thoven0215
Reply #9 on: April 29, 2022, 04:25:29 PM
My fuse ended up blowing. Do you have a recommended replacement, or can I just buy any 1.5 A fuse off the internet? Is there a specific area I should be looking to correct the fuse blowing? Thanks.
Sihwan
Reply #10 on: April 29, 2022, 04:39:09 PM
Your power supply diodes are installed backwards.
Any old 20mm 1.5A fuse should do the job.
Offline Thermioniclife
Reply #11 on: April 30, 2022, 07:07:41 AM
Good catch P.B.
Offline thoven0215
Reply #12 on: May 01, 2022, 09:21:30 AM
I replaced the fuse and went onto testing voltages, but when I got to terminal 27, there was a big pop noise and something bright. I disconnected the power. I noticed the tubes still glowed, but the measurement on everything went to 0 volts. The fuse is also still ok. What happened?
Sihwan
Reply #13 on: May 01, 2022, 09:49:51 AM
You have 0V at terminal 44?
Offline thoven0215
Reply #14 on: May 01, 2022, 09:54:28 AM
I have 423 Volts at terminal 44.
Sihwan
