Final voltage check slightly low
snoozzell · 6202
Offline snoozzell
on: April 29, 2022, 02:59:49 PM
Hi, just wrapping up the build and i was doing the voltage checks on the mje5731a metal tabs and on both amps im running slightly low of the spec on the A side.
296.4v and 296.1v on the left and right amps respectively
The manual said to look for 300+-1% so i figured id ask here if being a volt shy of the spec was anything build related i should look at or if i should just continue on.
Thanks a bunch for your time
Offline Thermioniclife
Reply #1 on: April 29, 2022, 03:20:43 PM
I wound not worry about those voltages as 300 -1% is 297volts.
