S.E.X. > 2A3 Monoblock OPT
Ken · 263372
Online Paul Joppa
Reply #45 on: May 17, 2022, 10:41:08 AM
The bleeders dissipate a bit over 0.5 watts. At full rating, inside a tube amp, they will get VERY hot! For reliability, they should be rated for at least three times the actual dissipation - you should use 2-watt resistors. A working voltage of 500v minimum is required, to survive the turn-on transient voltage.   #things_they_don't_tell_you_in_the_specs
The different part numbers indicate how they are packaged, loose individual components, or taped together in reels of 4000 resistors for use in automated insertion machines. See the spec sheet, bottom of the first page.
Reply #46 on: May 17, 2022, 10:59:31 AM
Offline Ken
Reply #47 on: May 17, 2022, 12:46:52 PM
Paul B:  that resistor shows out of stock at Mouser but I found an equivalent at PartsConnexion for pennies more.
Thanks to both of you for the education :)
"It is not that I am mad; it is just that my head is different from yours" - Diogenes of Sinope
