Screechy noise coming from left channel
thoven0215 · 6583
Offline thoven0215
on: May 15, 2022, 03:39:17 AM
Yesterday all of a sudden there was a very erratic screeching noise coming from the amp. I tried swapping the tubes to no effect. The volume control doesn't do anything to the noise. What could be the issue here? Thank you.
Sihwan
Offline thoven0215
Reply #1 on: May 15, 2022, 04:07:29 AM
After moving the tube a bit I noticed that it stopped, but any slight adjustment makes the noises come back. Should I just reflow the solder at the socket just to make sure everything is fine?
Sihwan
Reply #2 on: May 15, 2022, 04:32:48 AM
If you haven't cleaned the tube pins yet, that might resolve the problem without getting  out the soldering iron.
Reply #3 on: May 15, 2022, 06:07:15 AM
You can also use needle nose pliers to slightly bend the 4 pin socket contacts closer together, though you didn't say which tube you had to bend to change the nature of the noise.  It's also possible you have a solder joint that isn't 100%, and moving the tube around is disturbing that joint.
Offline oztayls
  • Still waiting for proof of the THING...
Reply #4 on: September 20, 2023, 03:45:42 PM
I presume you sorted out your problem? Did you find the cause?
Thorens TD124, TD125, ARXA, ARXB, Stereomour II (no mods), Spud Kit amp 2.3wpc, Boyuu A50 Mk3 300B 7wpc, EAR 834P, Leak Sandwich 15ohm, Leak Mini Sandwich 15ohm, Lii Audio Fast-8 OBs, Klipsch Heresy 1.5s, On the Decware 4-year wait list for SE84UFO2.1
