busted rocker switch
geezerizing · 3925
Offline geezerizing
on: January 05, 2011, 12:04:40 PM
oh the frustration - first kit ever, just about to plug it in for the very first time when I try the rocker switch (to see if I can figure out which way is ON) and it won't move at all. I look, and poke and try again and now it moves freely with no click. So I'm certainly not going to plug it in until I can replace the switch.
Can anyone tell me what the specs on the rocker switch are, and how I can get a replacement?
Thanks...
Offline QueenBottlehead
Reply #1 on: January 05, 2011, 01:29:49 PM
Sorry to hear about your broken switch! Please contact me so I can send another one out to you right away. Best Regards, Queenie
[email protected]
Reply #2 on: January 05, 2011, 03:11:55 PM
You can plug and unplug the amp with the power switch on.  Or you can solder the two wires on the switch to the same lug and use the plug.  It is inconvenient but I hate for you to be without sound while getting the replacement.
Offline geezerizing
Reply #3 on: January 05, 2011, 04:17:05 PM
Thanks-- a good idea. But actually, I have a pair of old Paramours as my backup amps -- the rocker switch appears to be the same, so while I'm awaiting the replacement, I'll pull the switch from a Paramour and install it into the Crack.
