Moreplay manual issue ? Page 51 bottom step
smodtactical · 2861
Offline smodtactical
on: July 01, 2022, 01:48:40 PM
On that step it says to attach and solder at the forward lower lug. But then on page 52 third step we are supposed to solder in a 33k ohm resistor in that same tab?
Is therefore an error in the first instruction (shouldn't solder) or am I making a mistake?
Offline ccmccull
Reply #1 on: July 02, 2022, 04:45:08 AM
Colin. Insta @act4audio
Reply #2 on: July 02, 2022, 06:12:00 AM
Thanks, I'll get the update made. Between the quantity of "attach and solder" instructions and the quantity of "copy and paste" commands to make a manual these kinds of things can happen when editing.
Offline ccmccull
Reply #3 on: July 02, 2022, 06:55:22 AM
Hi Doc, I don't know how you feel about volunteers on these kinds of things, but I'd be happy to help out editing for you.
Reply #4 on: July 02, 2022, 02:42:47 PM
Thanks CCM
Offline lms
Reply #5 on: July 11, 2022, 02:14:26 PM
Correct me if I'm wrong, but isn't page 30 incorrect as well? Or is one supposed to solder the STP to 6 and 7 then attach the resistor to 6 and 7 and solder again?
Offline Happy Ghost
Reply #6 on: July 17, 2022, 08:58:46 AM
Couple more minor errata in the manual.
1. On page 13, step 1 it says to install the #6 solder lug between the volume and the balance pot. It should be between the Input Selector and the balance pot.
2. There are all these 0.1uF 100V Z5U caps that we attach to the ground lugs. The manual is missing the step where it says to solder the ground lug connections once it is all done.
Atul
