Which direction should ODAM output capacitors go?
pinwa · 5372
Offline pinwa
on: July 06, 2022, 08:24:31 PM
I'm playing around with upgrading the output capacitors in the Moreplay.  The V Cap ODAMs I am going to use have a short lead that connects to the outer foil and the guidance is "The short lead indicates the outermost foil and should be connected to the lowest impedance path to ground."  But other guidance for capacitors I've seen would suggest that the outer foil should connect towards the source, i.e the tube.  Does anybody have an opinion about what orientation would be best?
Reply #1 on: July 07, 2022, 04:35:31 AM
The plate of the tube IS the lowest impedance to ground - about 2500 ohms, compared to the 10,000 ohms of the volume control.
Offline pinwa
Reply #2 on: July 07, 2022, 07:44:43 AM
Thank you.
Online Tom-s
Reply #3 on: July 07, 2022, 08:30:47 PM
The volume control is on the output of the circuit in this design?
Offline Thermioniclife
Reply #4 on: July 08, 2022, 03:49:55 AM
Yes
Offline Dzrout
Reply #5 on: December 30, 2022, 05:03:03 PM
So, which way did you put them?
