6K6 sub?
greg788 · 3040
Offline greg788
on: August 01, 2022, 05:12:46 PM
is there any reason I can't safely sub a 6K6? I know it may make the transformer run harder/hotter, but at 125V is that a concern?
Reply #1 on: August 01, 2022, 05:26:58 PM
The 6K6 draws a little less heater current, but it's not different enough that I wouldn't sweat it that much.  That will relieve some of the load on the power transformer.
The 6K6 also looks like it may draw a bit less high voltage current, but again it will be pretty close to the same.
I do not see any reason that the power transformer would run hotter.
« Last Edit: August 02, 2022, 04:12:43 AM by Paul Birkeland »
Offline greg788
Reply #2 on: August 01, 2022, 06:28:32 PM
Thanks, got it backwards, or whatever I read had it backwards
Offline oldtriode
Reply #3 on: September 19, 2022, 02:42:11 PM
Well, I'm late to this thread...but I have used multiple pairs of 6K6 tubes in the Moreplay.  They work fine, amp likes them, and you can experiment with the different sonic qualities of each pair.
