I have a magic Crack. After replacing pot, magnetic field buzzing?
trickyricky123 · 1238
Offline trickyricky123
Hello all,
Had built a fully functioning crack (without speedball) and was mildly annoyed by the fact there was channel imbalance - and very audibly so at low volumes. So I went ahead and replaced the stock pot with a blue Alps pot. (RK27112 100KBX2CC)
After the replacement, I notice an audible hum that gets louder as the volume goes up - when everything (RCA, headphones, etc) is plugged in.
Now, I noticed that when I unplugged the RCA cable from the jacks the humming turned into buzzing - very clearly audible at high volumes. RCA back in, the buzz levels lower. When the RCA cables are not plugged in (just power cable and headphones) - the buzzing responds to say, my hand coming closer to the back of the crack chassis. Or, when I touch the RCA cables with my fingers when they are not plugged into the crack but just nearby it, I can hear crackling/popping. (but only when those RCA cables are plugged into a DAC.. otherwise no)
The blue alps pot has been a pain to solder, as it seems to need a much higher temperature for its pin to finally 'stick'. Is this a bad solder job on the ground pins potentially? Anyone have an idea?
All voltage/resistance checks match up - some voltage readings seem to be a bit higher than before but all within nominal range.
Much appreciated.
That's a linear pot with a stereo detent, so not a suitable replacement for the stock part.
https://forum.bottlehead.com/index.php?topic=4295.0
Item #3 in the Crack FAQ will address the channel imbalance, which may be imbalanced even if you put a proper log Alps pot in there.
Alps pots absolutely must be soldered to a PC board, so if you wrapped wires around the pins on the pot, those pins will break off sooner or later.  PCBs are available on eBay for these pots.
What I would suggest is either putting the stock pot back and adding resistors, or adding a proper log pot with solder lugs like the TKD or PEC pots.
That explains it! Thank you!
Would anyone suggest a better alternative out of these 2?
SWITCH-211-V2: Audio Note 100K dual log potentiometer
TKD Ko-on 2CP-2511 100K dual log potentiometer
Thank you!
« Last Edit: August 30, 2022, 08:23:48 AM by trickyricky123 »
Buy the one that makes you happy.
