Bottlehead Kits
Crack
How to replace pin on resistor
Swollazn
2025
Swollazn
Jr. Member
August 30, 2022, 12:45:29 PM
One of my pins broke off the big 10w 3k resistor. I tried to solder it back on but that wouldn't work.
Anyone have any ideas how to fix this
Swollazn
Jr. Member
Re: How to replace pin on resistor
Reply #1 on:
August 30, 2022, 12:57:21 PM
3K ohm 3KRΩJ 10 watt Axial Ceramic Cement Power Resistor 10W
Can i purchase this off amazon and achieve the same thing?
Thermioniclife
Sr. Member
Reply #2 on:
August 30, 2022, 01:32:07 PM
If it is broken off at the body of the resistor you are S.O.L. contact Eileen at Bottlehead for a replacement or order one from a supplier like Mouser. but you will probably save money by ordering from Bottlehead.
Swollazn
Jr. Member
Reply #3 on:
August 30, 2022, 05:05:45 PM
I ordered a replacement from amazon, it should be the same (ceramic resistor with same specs). But I emailed them just in case if that would work.
Paul Birkeland
Global Moderator
Hero Member
Reply #4 on:
August 31, 2022, 04:35:11 AM
If it's a 10W 3K resistor and it fits in the space provided, it will likely work just fine.
Bottlehead Kits
Crack
