Volume low connected to Scarlett 2i2 [resolved]
Swollazn · 3951
Offline Swollazn
on: September 01, 2022, 06:55:13 PM
Hey all,
I believe I got the crack working. Most voltages and resistances looked good with a dmm.
I find it really quiet when connected via AUX cables connected from Scarlett 2i2. Is there a way to boost the volume with this setup? The potentiometer (volume knob) is turned all the way right. Thanks!
Also I don't see the LEDs on the bottom side of 12AU7 lighting up, but the upper tube 12AU7 is definitely lit.
« Last Edit: September 02, 2022, 11:49:53 AM by Paul Birkeland »
Offline Swollazn
Reply #1 on: September 01, 2022, 06:58:21 PM
Actually playing the potentiometer more.
When turned ALL the way LEFT (it is more loud, but only left channel works w/bass)
When turned ALL the way RIGHT (it is quiet, both channels play with no bass)
Is it supposed to be volume knob?
Offline Swollazn
Reply #2 on: September 01, 2022, 07:00:30 PM
And unplugging the Red RCA doesn't do anything, the left side of my headphone still plays.
Offline Tom-s
Reply #3 on: September 01, 2022, 07:12:17 PM
Double check your wiring on the potentiometer and the RCA sockets.
And the wiring for the 9 pin socket.
It may help to post pictures.
Offline Swollazn
Reply #4 on: September 01, 2022, 08:26:10 PM
attached are some pictures
Offline Tom-s
Reply #5 on: September 01, 2022, 09:42:08 PM
Please have a second look at your volume pot and compare your wiring to the manual.
It's hard to tell from the pictures. But it appears to have a shorted input.
Further. Do note the "WHOA! Soldering lesson!" page in the manual. Make a physical connection; attach a lead; before soldering.
If most voltages look good would indicate some don't. Do post them here and don't use the Crack with headphones before they are good.
Offline Swollazn
Reply #6 on: September 02, 2022, 04:35:25 AM
Thank you, i totally missed the black wire not going to the upper lug (top image of pg 34). The volume is all taken care of now and the LEDs are on.
I'll spend the weekend fixing up the humming etc.
Offline Swollazn
Reply #7 on: September 02, 2022, 04:43:34 AM
Actually i'm using a Hydria Model 2 power conditioner. The Crack sounds lovely and stunningly clean, I'll install the speedball next week!
Reply #8 on: September 02, 2022, 11:49:44 AM
I would get a pair of proper side cutters also to help trim back all those leads poking out.  The CHP-170 is less than $10 and does an excellent job.
Offline Tom-s
Reply #9 on: September 03, 2022, 04:13:41 AM
I'd recommend to first get rid of the hummmmm before you start the Speedball upgrade.
Offline Swollazn
Reply #10 on: September 05, 2022, 05:25:38 AM
good ideas on trimming the leads, I solved most hums with a power conditioner. But there's humming on the right channel if i turn the amplifier volume all the way down. I wonder if its the amp or the computer wires.
Reply #11 on: September 05, 2022, 06:27:13 AM
Does this go away with nothing plugged into the Crack?
Offline Swollazn
Reply #12 on: September 05, 2022, 08:35:05 AM
With RCAs unplugged I hear buzzing on max volume.
Offline Swollazn
Reply #13 on: September 05, 2022, 08:37:57 AM
Also the buzzing changes when I move the AUX cable about
Reply #14 on: September 05, 2022, 03:00:23 PM
Yes, you'll get buzzing with no cables plugged into the Crack and the volume cranked all the way up.  What I'm wondering is if you have the volume control all the way down and nothing plugged in, is that silent?
