Moreplay Resistance Question
jminassi · 2320
Offline jminassi
on: September 08, 2022, 10:10:09 AM
All resistance readings are within range per page 57 of the Moreplay manual.  But I can swing the resistance readings at A5 and A6 and at B5 and B6 by rotating the balance control.  It occurs to me that this may be normal as you are effectively changing the resistance with the pot.  If I center the pot (approximately) I get readings of approximately 53,000 ohms at A5, A6, B5 and B6.
Am I ok to proceed to voltage checks or is something going on here that I don't understand?
Many thanks,
John
Reply #1 on: September 08, 2022, 11:30:15 AM
Yes, that is normal and you can proceed to the voltage checks.
Offline jminassi
Reply #2 on: September 08, 2022, 11:32:10 AM
Thanks Paul!
