Moreplay Complete: No sound on right channel [resolved]
jminassi · 11227
Offline jminassi
Reply #15 on: September 11, 2022, 01:29:48 PM
I just tried it.  Still no right channel signal.  The left channel sounds really good.
John
Reply #16 on: September 11, 2022, 02:29:09 PM
Now turn the volume pot up about half way, turn the preamp on, then measure the AC voltage at terminals 9 and 19.
Offline jminassi
Reply #17 on: September 11, 2022, 02:52:01 PM
PB, I get 0.197 at 9 and 0.223 VAC at 19.
John
Reply #18 on: September 11, 2022, 03:35:38 PM
Is that with the preamp powered up?  With 1V of signal going into each 6V6 socket, we would expect more than 1V to be coming out...
Offline jminassi
Reply #19 on: September 11, 2022, 03:49:15 PM
Yes Paul, those readings are with the preamp powered on, volume about half way.  Negative lead of DMM is still on solder tab 23.
Offline jminassi
Reply #20 on: September 11, 2022, 04:04:12 PM
PB,  I had the volume on my iPad all the way up, but the tone generator app has its only volume control.
I turned that to max too.  Now I get 3.66 VAC on 9 and 4.07 VAC on 19.  I hope that makes sense.
Reply #21 on: September 12, 2022, 04:32:48 AM
What are the AC voltages at the center lug on each level of the volume pot?
Offline jminassi
Reply #22 on: September 12, 2022, 05:21:54 AM
PB,  should I measure the voltages on the center lugs of the volume pot with the preamp turned on?
Reply #23 on: September 12, 2022, 05:45:44 AM
Yes.
Offline jminassi
Reply #24 on: September 12, 2022, 05:50:25 AM
With preamp powered on and preamp volume pot half way up the top center lug measures 0.536 VAC and the bottom lug measures 0 VAC (?).
Reply #25 on: September 12, 2022, 08:21:32 AM
Turn the preamp off and measure the DC resistance between ground and each of those middle lugs on the volume pot.
Offline jminassi
Reply #26 on: September 12, 2022, 09:00:04 AM
Volume pot top lug resistance to ground is 1.429kohms; bottom lug is 1.412kohms.
Reply #27 on: September 12, 2022, 09:25:24 AM
Can you use your meter to measure the resistance between the center lug on each level of the volume pot and the lug behind it (where the white and red wires land)?
Offline jminassi
Reply #28 on: September 12, 2022, 10:26:43 AM
PB,
Top measures 9.15 Kohms (top center lug to lug with white wire) and bottom measures 9.36 Kohms (bottom center lug to lug with red wire).
Reply #29 on: September 12, 2022, 04:33:58 PM
There's something kind of impossible about all of the data you've posted.  My best guess is that you have a loose connection somewhere around the wiring going to the volume pot that is causing the issues you're having.  Ultimately you cannot have those four resistance values and not have any voltage coming out of half of the pot without some kind of connection issue at work.
