Moreplay Complete: No sound on right channel [resolved]
jminassi · 11217
Offline jminassi
Reply #30 on: September 12, 2022, 05:04:59 PM
Ok Paul, this is helpful.  Let me see what I can find.  I'll report back.
Thanks for guiding me and wading through all the measurements.
John
Reply #31 on: September 12, 2022, 05:44:58 PM
Yes, double check those center lug AC signal voltages to verify the bottom lug is zero.
Offline jminassi
Reply #32 on: September 12, 2022, 06:33:47 PM
Doc and PB:  It's fixed and it sounds great!  Listening to Brian Auger's Oblivion Express album Straight Ahead.  Wow!  See picture.
I re-flowed the solder on the volume pot connections.  Also, you know that balance pot lug that is tricky due to having 3 heavy black wires in that tiny pot lug?  I re-made that connection which was kind of wonky.  When I measured the voltage on the right channel lug of the volume pot......there it was: a signal!
This would have taken me forever without your help Paul.  I apologize if it was torture.
This is significant because I built this one for my friend Tony.  Now I get to build one for me.
Thanks again,
John
Reply #33 on: September 12, 2022, 07:06:17 PM
Well done - both of you!
Online Paul Birkeland
Reply #34 on: September 13, 2022, 03:58:39 AM
 ;D
Impossible readings are indeed often nothing more than a missing ground connection. I'm glad you found it.
Offline jminassi
Reply #35 on: September 13, 2022, 04:44:23 AM
Thanks PB!
